deleted smog whats the deal with the heads?
I just put an o r H pipe and longs in my car over the weekend. I just completely nixed the entire system. Just take out the bolts in the back of the heads remove the tubes and put back in the bolts. Thats what I did anyway
all you need to do is cut the line off completely from the back off the heads .
and flip that little block around on each head to totally block it off, and just tighten it with the bolt.
if you dont do this you will leak air from your heads.
