Thanks bro but already ahead of you however with whiskey insteadNice pics, hope he see's them.
Now wash them hands and have a beer!
I'm getting ready to pull my engine and removed all the front accessories and saw my charcoal canister and purge solenoid and remembered this thread so I took a couple pictures for you. Hope this helps.![]()
Need the wires hooked to the solenoid for it to work, can't remember what size vac line is. Sensor is measured in olms, not volts.
I may be wrong, but the sensor, unplugged would be measured in olms, I always have trouble when testing resistance. I would think voltage is tested with the wires hooked up, power on?
saving the $80 and just put this new sensor in and be down with it
Unplug the solenoid and measure the resistance across the two prongs inside the connector sitting on it.
You don't need to test the wiring.
This is that the computer does when the codes are run. If the resistance value is out of spec, you get your code 85.
Sent from my iPhone using Tapatalk
I do read the post as do others, sometimes I have to reread the post, sometimes I get confused and sometimes people post in a confusing manor, not meaning to bugger you up, replace the ect sensor, I think the sensor test is conducted with the sensor unplugged and measured in olms, but again I get confused easily.
Note: some on here use their I phone thingies to monitor the site and does not show entire post to them, I use some kind of pad thing, kendel or I candel, I'd have to ask one of the kids what it is.
out and am ready to move onto the next part of the diagnosing which involves answering 2 questions I have repeated multiple times, and people are not answering the question but suggesting I try the stuff that was done 3 days ago and are asking me the questions instead of helping answer the 2 yes or no questions I have put forth!! Ah the internet, I'll get there, thanks for the advice, come along way since I got her couple months ago and it wouldn't start!This is how you test resistance of a sensor. Disconnected from factory wiring
Can you do this for say the ECT sensor with it still in the car with the battery disconnected and plug removed so I can probe the pins? Here is a photo of my particular dmm, which of the ohms setting should it be on? And than do I just refer to jrichkers chart?It is confusing because different people are saying to test it in different ways. I don't get the voltage chart for checking the sensor that I have seen on here if others are saying it should be measured only in ohms? Is there a test measuring voltage and a separate one for measuring resistance in ohms that both will let you know if the sensor is toast? I learn quick and the car has come along way in the past month but its tough when you get told different things!
And now back to the original purpose of the post. I went and picked up the purge valve solenoid, there were 2 options. One with the pigtail and one without. I originally got the one without as this is all they had, but returned it for the pigtail one as that is the one shown in all the photos provided to me on here. I have attached a photo of me holding it next to the plug its supposed to plug into. Problem is they do not match, so now what? Do I need to order one from a different manufacturer?
The way I'd test it is to set the DMM on ohms. I'd prob use the 200K scale. Unplug the wiring and just probe the sensor. No need to touch the battery.
I'd look at his chart for 68-86 degrees (ambient temp)
68 degrees F = 37.30 K ohms
86 degrees F = 27.27 K ohms
If your value is in that ballpark, you are good. If it's waaaay off. Sensor is bad.
