There are so many variables potentially at work within a particular engine, I wouldn't rely on someone else - even the cam company - to determine proper pushrod length. I'd measure. They make adjustable pushrods that can be used to determine the length that gives you proper geometry. Alternatively, you can tighten down your rocker arm, hold the rocker in contact with the pushrod, and use a feeler gauge to measure the gap between the rocker tip/valve stem. Add that gap, + .03" to your stock pushrod length, and you should come up with a length that will work. Be sure the lifter's on the cam base circle, and that you're not depressing the plunger in the lifter during the measurements. Measure all 16, and pick your length based on the longest. That way you can always use a .030", or .060" shim to adjust. If you end up with them too short - well, that's the problem you're trying to solve. Also, I wouldn't assume a length on the stock pushrod - I'd measure them and use the longest as your guide.
