dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
its not necessarily the dexcool that is the problem its the recommended service intervals that gm had for that coolant. it was in the cars so long that i was causing electrolysis and was eating aluminum parts left and right. the biggest problems were in the cars that had the iron blocks with aluminum heads. the dexcool also doesnt mix with the green stuff. it causes horrible sludging and clogging. i would just take it out and run the regular green coolant or make sure you change the dexcool every year or so to keep it from eating stuff. you can use a digital multimeter to see if your coolant is bad if anyone didnt know. just turn it on to the ohms and ground one probe and drop the other into the radiator without it touching the sides. i think a good reading is anywhere up to .04 ohms is good and about .05 ohms is bad and needs to be replaced. i might be off with my voltage since its been a while since ive done it but its either .04 or .4...something in that area. maybe someone who has the definet readings will chime in
