From that picture those are clearly not factory lobes. I can tell by the nose radius and lift alone. Those don't appear to be welded lobes but rather a PM(powdered metal) lobe that has been diffusion bonded to the core by means of heat. Some of the factory Ford camshafts are done this way and some are manufactured with the process that MBDiagMan descibed. But these are processes only used by Ford, not aftermarket cam manufacturers.
All the modular camshafts that are produced by aftermarket companies such as Comp, Crane, and Crower machine and grind our cams from one big chunk of round bar stock...billet. These companies also make cast camshafts that are finish ground, but all of the aftermarket modular cams by these companies are billet. And I know at least Comp, Crower, and Crane do not re-grind factory camshafts and have never done so. The modular camshafts from them have always been billet.
If I were you, I would go spend $30-$50 bucks and take your cams to somebody local that has a Cam Doctor or Cam Pro. They will run both cams through the machine and give you a very accuarate cam specification card. This way when you degree the camshafts you will know the cam specs.
BTW the flank is the uppermost part of the ramps closest to the top of the nose radius (peak lift). The heel is the bottom of the base circle. To measure lift, first measure with a caliper the width of the base circle, and then measure from the center of the heel to the peak of the nose radius and subtract the difference.
