Alright, I just finished doing a hci swap. I installed the trick flow kit along with new injectors, maf, tb, etc. Before starting, I did not prime the motor. I did however squirt about ½ quart of oil on each head with an oil can. I tried to ensure oil was squirted on the valve guides per the tf instructions. My first attempt to start did not succeed and it turned out I had the dist 180 degrees off. I prolly only cranked for 10 secs total before I realized this. I fixed the dist and she started right up. Seemed to idle ok and I let it run for a few minutes while I checked for leaks and set timing. That’s when I checked the oil and noticed metal shavings in it. They are very fine metallic shavings of aluminum (I have magnetic drain plugs – nothing on them). I drain the oil and put in new. Start the car again and let it idle for about 10 mins. Turn it off and check the oil – lots of very small metallic shavings. So, what do you guys think? Did I ruin the motor by not priming? Was not pouring oil on the heads enough? Or is it normal to have these shavings during initial break-in? Thanks.
