Did My Own Alignment*pics*
I aligned my car myself today. I bought a caster/camber gauge along with a toe gauge. Setting the camber/caster is very easy. The toe is simple, but just takes time. You also must be careful to turn each tie-rod the same when changing the toe. It is raining here so I didn't have a chance to see if I turned them equally
I used the following setup:
Caster: positive 5.5 degrees
Camber: negative 1.0 degree
Toe: IN 3/32"
Here is one pic of the toe gauge and three of the caster/camber gauge. It all cost $240, but the caster/camber gauge is very nice and comes with a case. I can also change the settings whenever I want, which is the point of adjustable C/C plates.
<img src="http://www.mustangmods.com/data/393/79627960.jpg">
<img src="http://www.mustangmods.com/data/393/p4241155mm.jpg">
<img src="http://www.mustangmods.com/data/393/p4241156mm.jpg">
<img src="http://www.mustangmods.com/data/393/p4241157mm.jpg">
Toe: IN 3/32"
