Died Today
  • Thread starter Thread starter 87redgt
  • Start date Start date May 18, 2009
87redgt
32
Richmond, CA
May 18, 2009
  • May 18, 2009
Today I was driving, doing about 55 mph, when all of the sudden it felt like my car lost some power, I looked at the rpms and they kept dropping down to about 300 and jumping to about 2500, this went on for about 10 seconds and then it died. I coasted to the edge of the road and tried to start it, but it took about five key turns to get it started and I drove it for about 10 minutes to get home and it ran perfectly fine . I've owned the car for about a week now and have put almost 200 miles on it and this is the first time anything like this has happened. Does anybody know what could cause this, if it is a common problem, or if I should start looking for something?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 18, 2009
  • May 18, 2009
Dumping The computer diagnostic codes on 86-95 Mustangs
Revised 19-May 2009 to add information to Dumping codes with no check engine light drawing.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
87redgt
32
Richmond, CA
May 18, 2009
  • May 18, 2009
I found the connector it says EEC something(cant remember exactly) looked pretty much like the one in the picture, but it was a little bigger and it had like 3 wires plugged into it. Do you know if those code readers will work on cars witthout a check engine light?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 19, 2009
  • May 19, 2009
All of the 5.0 Mustangs from 86-95 used the same diagnostic connector and scanner/code readers. The presence or absence of a check engine light was not a concern when using the correct scanner/code reader.
If you will re-read my previous post, you will see that the red jumper wire and the automotive test lamp are not present until you install them.
bradleyem
186
Columbus, Ohio
May 19, 2009
  • May 19, 2009
Erratic RPMs, especially in hot weather is commonly caused by a failing ignition module (on the side of the distributor). Usually, it will start out intermittantly, and if you shut the car off and let it cool down, the idle will smooth out. Then when it heats up again, it will start running rough again.
Dino Dino Bambino
1,673
90
79
Cyprus
May 20, 2009
  • May 20, 2009
I agree. That makes a lot of sense. Now that we're getting into the hot summer months, ignition components that are prone to heat soak (ignition module and PIP sensor on Fox Body 5.0's, PIP sensor alone on SN95 5.0's) will be more likely to fail.
In this case I'd say it's the ignition module because of the erratic rpm before the engine died. A bad PIP sensor will usually just cause the engine to die suddenly as if you tripped a kill switch.
87redgt
32
Richmond, CA
May 20, 2009
  • May 20, 2009
It happened again today. This morning it did it after about 15 mins. of driving, the rpms were eratic and jumping up and down, it didnt die, but when I stopped the idle was strange, it was going from 500 rpms to 900 rpms. Then again after work I started my car and the idle was around 900(its usaully around 600) it finally dropped down after about 30 seconds. After driving it for about 10 mins the rpms were eratic again, but it didnt die, it was acting like that for about 2 mins. Then it drove okay(it was only about another 5 min. drive home). Does this still sound like an ignition problem. This is the first ford I have ever owned, my previous car had no computer or anything, so I have no idea where to start on this car.
bradleyem
186
Columbus, Ohio
May 20, 2009
  • May 20, 2009
Yep, still sounds like the ignition module.....at least thats where I would start. It'll probably get worse as the weather warms up too......
Plus its a pretty cheap part....around $35 at VaderZone.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 20, 2009
  • May 20, 2009
Dump the codes. A bad PIP sensor will often set code 14. Other codes may be present that will help you find the source of the problem.
87redgt
32
Richmond, CA
May 21, 2009
#10
  • May 21, 2009
  • #10
What is a PIP sensor? I cant find it listed on Kragens website.
bradleyem
186
Columbus, Ohio
May 21, 2009
#11
  • May 21, 2009
  • #11
The PIP sensor (Profile Ignition Pickup) is a hall effect sensor that is located inside the distributor underneath a metal cap right below where the rotor is. It is what senses the rotor position and generates the ignition pulses to fire the ignition. Typically, if this sensor is bad, the car will not start at all, or it will just die when the sensor heats up. It typically doesn't cause the surging idle problem that you're experiencing. Reading the codes is a good suggestion, but keep in mind that you may or may not get a trouble code. When my ignition module went bad, it never threw a code.
bradleyem
186
Columbus, Ohio
May 21, 2009
#12
  • May 21, 2009
  • #12
Also, two other things that can cause rough idle/surging are the IAC (Idle Air Control) valve and the EGR valve.
The IAC valve can get carbon build up that will cause rough idle, and the EGR valve can stick, and cause similar symptoms. BUT, usually these will only cause a rough idle, not surging at higher RPMs (when you're on the gas) and they usually will not cause the car to die.
87redgt
32
Richmond, CA
May 21, 2009
#13
  • May 21, 2009
  • #13
Just picked up the ignition module tonight at autozone. It was too late to put it on so I'll have to do it tomorrow and I'll give an update in a few days to see if it made a difference.
87redgt
32
Richmond, CA
May 22, 2009
#14
  • May 22, 2009
  • #14
Installed it today, the old module had no grease on it. Drove the car for atleast 30 mins. with no problems. I'm keepin my fingers crossed hoping this fixed it.
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
W
  • Locked
Fox Wifes 1993 LX 5.0 dies after replacing ignition parts
  • Warhorse85
  • Aug 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2025
N
04 mustang v6 crank runs then dies
  • NewEdgeRacer
  • Feb 28, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 19, 2025
89ripper
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
