?? Ok, edelbrock rpm intake, edelbrock heads, custom ground cam, 60lbs injectors, msd 6al, stock coil, 14lb procharger. The ecu isn't showing anything abnormal before the motor dies. I didn't think any of the above was relevant to the spark issue. Thanks
moment. LoLIt all Chi knee crap.Sounds like a lot of bad TFI modules going around recently.
Bad electrical connection.Hello all, having a issue where the car will loose spark while running. If I cycle the key off then back on it will start and run. Bought a motorcraft tfi module and it does the same thing. Could it be the pick up inside the distributor?? Thanks
