  • SN95 4.6L Mustang Tech
diff problems after bearing change
  • Thread starter Thread starter lillefan2005
  • Start date Start date Jan 23, 2013
L
lillefan2005
Burlington, NC
Jan 23, 2013
  • Jan 23, 2013
ok I bought a yukon diff bearing kit. I installed it and now when i put on the diff housing clamps the diff doesnt turn/ any help?
94GTCoupe
1,412
92
79
CA
Jan 23, 2013
  • Jan 23, 2013
Did you fully seat the bearings on the diff?
You should use one of the old bearings to press the new ones on.
Did the caps go on the correct sides, with the correct carrier shims?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jan 23, 2013
  • Jan 23, 2013
+1 on above. Explain HOW you set the pinion preload. Explain how the bearings were removed and the new one's installed. Did you take any measurements of the pinion depth before dis-assembly?
Is it possible it's not turning because the back-lash is zero (or negative)? If so, this could be because of the pinion depth or carrier shims.
Reactions: trinity_gt
trinity_gt
3,125
81
99
Canada
Jan 23, 2013
  • Jan 23, 2013
Agreed, something is definitely not right in the setup.
L
lillefan2005
Burlington, NC
Jan 24, 2013
  • Jan 24, 2013
Ok thanks wmburns. I checked the pinion and it was not set correctly. I bought the a few days ago so I didnt know how the gear was done or who did it. Evidentaly that is why the diff bearings went bad. Reset the pinion and now all is good in the mustang world. Car feels like it has 50 more horsepower now. Thanks
Reactions: gearheadboy
R
rockyracoon
874
27
49
margate NJ
Jan 26, 2013
  • Jan 26, 2013
I dunno sounds like something else was wrong ,like incorrect carrier bearing preload.
It seems to me that if it was a pinion depth issue you would be most likely to have issues with the inner and outer pinion bearing and not carrier bearings as your post seems to imply. JMHO
Drivetrain 8.8 trac lok spider gears..
  • rednotch
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 28, 2025
rednotch
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
O
Progress Thread LTD-ing
  • OX1
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 6, 2026
OX1
O
Drivetrain Rear end clunk
  • seanmahoney
  • Oct 13, 2025
SN95 4.6L Mustang Tech Oct 13, 2025
nickyb
