  • SN95 4.6L Mustang Tech
Diff. question
  • Thread starter Thread starter MustangMan00
  • Start date Start date Nov 14, 2007
M
MustangMan00
9
  • Nov 14, 2007
hey is this just useless weight....i heard it was, can I just take it off?
PUNISHER RACING
1,124
FORD CITY, PA.
Nov 14, 2007
  • Nov 14, 2007
yup!
Flghtmstr1
572
Springfield, PA
Nov 14, 2007
  • Nov 14, 2007
Um...I wouldn't take it off just yet. It is there to minimize the effects of harmonic vibrations at certain driveshaft RPM (or something like that). I remember reading somewhere not to take it off. I'll try to find the link...
M
MustangMan00
9
  • Nov 14, 2007
damn man u need a better tuner... im makin 242 rwhp with a dyno tune on 87 and o/r x, magapack catback, and k&n filter, butu got me on tq i got 264
BurningRubber
1,865
24
58
Nov 16, 2007
  • Nov 16, 2007
Yes you can remove it. Mine literally was hanging on by 1 bolt and slamming into the car so I yanked it before it fell off and hurt someone or damaged my or another persons car.
It supposed to balance harmonics but go look and see how many other cars on the road are using that.
Flghtmstr1
572
Springfield, PA
Nov 16, 2007
  • Nov 16, 2007
My numbers are through an auto...also, remember that I have a catted X and I'm still running the stock catback. As for the dyno run itself, I "hot-lapped" my car, and in the excitement I forgot to use the dyno fan at the shop, so I'm definitely making more power than the numbers would suggest. At the dyno, I wasn't as concerned with my numbers themselves as I was with tuning my car, which is what a dyno is truly for. I got it to the point where my AFR was pretty much perfect on my last run. My car pulls considerably harder now, and thats what I was going for.
One last thing about the dyno; my torque is undoubtedly higher than 280 because I had to start my runs at 4250 rpm to keep from downshifting, and 4250 is my torque peak on the dyno graph
As for the question of whether to remove that "dogbone" thing, just because other cars don't have it doesn't mean ours don't need it. Why would Ford bother putting something that heavy back there if it wasn't necessary?
96GTstang46
142
Seattle, Washington
Nov 16, 2007
  • Nov 16, 2007
Well i know some people take it off and dont take a 2nd thought about it. While others say it needs to say on..
Now for my .02 i am kinda pulled in the middle, just like you are MustangMan00.
My best friend has a 98gt and has his off.. his car is just fine, but i was told that it was more for noise and the travel of the diff while on the road. Thus the heavy weight to pull the diff down while driving over bumps in the road or something..
Less weight (bolts) = more power!!!!
jk I could be 100% wrong on this, but i would like to see more posts
RandyStinchcomb
1,159
Randallstown, Md
Nov 16, 2007
  • Nov 16, 2007
just an FYI: if You Do Take it Off....Make Sure you re-install the upper stamped steel brkt, as thats the contact point for the rear pinion snubber...........
CobraRed_96_GT
1,421
UCSD/La Jolla
Nov 16, 2007
  • Nov 16, 2007
thats the point where i jack up the rear end, why would i take that off?
Scorcher2005
883
South Carolina
Nov 17, 2007
#10
  • Nov 17, 2007
  • #10
I was always told that that was for vibration, but it only works on stock gears. Meaning if you change your gears, it isnt as effective. I took mine off on my fox, everything was fine and all.
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Nov 18, 2007
#11
  • Nov 18, 2007
  • #11
That is the word.I know many that don't have it on once they swapped gears with zero issues,including myself.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Nov 18, 2007
#12
  • Nov 18, 2007
  • #12
I left mine on both my Mustangs.
C
New member from NJ
  • Calyp5.0
  • Sep 25, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 25, 2026
General karthief
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
