From the "Mustang 5.0 Technical Reference and Handbook" the suspension changes are as follows:
"To increase wheel caster (and improve steering geometry during suspension compression), the tops of the front struts were relocated rearward, slightly closer to the cowl in the 1990 model. This improves cornering (by reducing understeer) and may also have a positive effect on tire wear. The K-frames's lower control arm pickup points were again repositioned to increase caster and improve both cornering ability and tire wear by reducing understeer. These revisions to the lower control arms' pivot points in the 1990 and later K frames adds caster when the control arm is compressed (during cornering and/or braking). Raising the front arms' inner pivots also effectively lowers the car's front roll center."
This book is the 5.0 Fox body Bible. This is Mustang Gospel.
