Difference in ignition coils?
88 Fox GT
1,674
Iowa
Whe converting from the SN95 engine electronics to Fox electronics, does the coil need to be changed? On the SN95, the coil had a condensor type of thing mounted to the side of it with a connector on it which connected to the harness. The Fox harness does not have this connector. Will the coil work properly without it or do I need the proper coil?
i dont know what the ballast thing is you speak of, but i seem to recall that coils are sold for 87-95 stangs - same part number (im not super sure on that; it is just my recollection).
now what to do with the thingie you have - i dont know.
good luck.
