Fox Differences Between The 2016 2.3t And The Turbo Coupe 84-86 Engines?
Undeadknight26
97
15
29
Florida
Hey guys not sure where I should have posted this or if you'll rage because of these two questions but just questions. What are the differences between the Thunderbird Turbo Coupe engines and the 2016 2.3 Turbo engines? Can the 6 speed transmission and DOHC head bolt to the older style block? Thanks in advance!
I would have to look up the specs and such, but I would almost guarantee that you couldn't use the heads on the old block.
I would look at the direct injection of the newer four as one of the key areas that would cause problems.
Good question though, something for me to look into for myself.
I was going to do the Folvo swap but then again you can swap a cheap 5.0 in a car and turbo it for around the same price and make more power. It totals up to like 1200 to find/make the parts to do a Folvo swap. Do you guys mind if I ask another question?
