Different oil recommendations?
281CI96Coupe
233
I am concluding that all mustangs aren't built equally from the factory because i was chatting with a friend that has the same car as me]ine but his car takes 5.5qtz of oil while mine, and my best friends takes 6.5-6.7qtz of oil? Mind you that they both real full at the dipstick line. 96-98 GT's.:shrug:
-Nate
My car holds 6 quarts, my manual even states that amount. I change oil at my job on all kinds of cars. i get alot of 4.6 motors, mostly in vics, i know the NPI motors usually hold 5.5qts and the PI motors hold 6qts. If anyone wants to know, i have a book at work that list what each car holds, its at work i'll look through the 99-04 4.6 years tom. Also fords take a little bit for the oil to run down, after i start the car (to look for leaks aka double gasketed filters)and shut it off before i check the oil, i remove the cap and pull up on the stick so i get air pressure to help the oil run down, after 30 seconds i check the oil.
