Different when hot
  • Thread starter Thread starter Thebluefox1
  • Start date Start date Jun 28, 2022
T
Thebluefox1
32
Pasadena
Jun 28, 2022
  • Jun 28, 2022
Thanks in advance for responses
When I start the car it runs and brakes normal but after a while of running I think when it gets hot the brake pedal is hard and barely moves but it still brakes and I need to press the accelerator deeper for it to run I think it is the caliper because it smells like brake pads but would it not work when it’s cold as well?
General karthief
Mod Dude
Aug 25, 2016
27,993
10,619
213
polk county florida
Jun 28, 2022
  • Jun 28, 2022
I would rebuild the front brakes, pads, rotors, calipers and hoses.
The main problem likely is the caliper seizing up or the hose has collapsed on the inside. JMO and not based on any real mechanical training.
T
Thebluefox1
32
Pasadena
Jun 28, 2022
  • Jun 28, 2022
I think I just going to replace the caliper And see if it changes anything
General karthief
Mod Dude
Aug 25, 2016
27,993
10,619
213
polk county florida
Jun 28, 2022
  • Jun 28, 2022
You can do that.
But think about it a minute, both calipers are the same age (or should be) and suppose to be replaced in pairs, same thing with the hoses, they are likely original.
brakes are something that needs to be in tip-top operating condition.
Reactions: limp
T
Thebluefox1
32
Pasadena
Jun 28, 2022
  • Jun 28, 2022
You can do that.
Thanks for pointing that out because I change pads and rotors but I’m not sure about the calipers
General karthief
Mod Dude
Aug 25, 2016
27,993
10,619
213
polk county florida
Jun 28, 2022
  • Jun 28, 2022
You didn't say what year or how many miles but a 93 stang is 27 years old. Do what you want, just giving advice here.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,495
2,916
173
Florida
Jun 28, 2022
  • Jun 28, 2022
If you recently installed new pad, its a Good chance when you pushed the caliper pistons back in they are now hanging up on the crud on the caliper walls and pistons....
Did you ever flush your brake lines?? A needed service that most people do not do.
Mustang5L5
Mod Dude
Feb 18, 2001
43,275
17,965
224
Massachusetts
Jun 28, 2022
  • Jun 28, 2022
When the brakes get all wonky donkey, can you Jack up the wheels and spin them and see which ones are seizing up?
There’s a lot this could be. Bad calipers. Collapsing hoses. Crud in the brake fluid causing a blockage because rust is in the system?
One of these things where you really need eyes on the car to properly diagnose.
I would narrow down what wheels the issue is on (front most likely) and go from there.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
