  • SN95 4.6L Mustang Tech
Differential Fluid?
  • Thread starter Thread starter JayDPee
  • Start date Start date Apr 1, 2007
J
JayDPee
14
  • Apr 1, 2007
Please help anyone. Bought a 1996 Cobra last year and finally got around to changing the differential fluid. It has a T/A girdle with a fill and drain plug.
No problem draining. But I'm trying to fill it and it appears to be eating the fluid. I've put in 6 quarts so far, and I'm just starting to top off. The Chilton's and a number of websites list capacity at 6.6 pints, I'm double that already with no end in sight.
Please help, she needs to get back on the road.
Thanks.
C
carvermach
23
Carver, Ma.
Apr 1, 2007
  • Apr 1, 2007
Are you checking it by the hole in the cover or the plug in the front of the rearend ? Just changed to a after market cover and mine took 2 quarts.
G
GettinThere
553
Central Texas
Apr 2, 2007
  • Apr 2, 2007
Thanks.
Just did a gear swap recently (4.10s ROCK!). I don't know about the 96 Cobra, but my 02 GT takes 4.25 pints. That came to 2 quarts (of RP 85w140 synthetic) plus the friction modifier.
If your Cobra is supposed to take 6.6 pints, then only put in 6.6 pints. It sounds like you have overfilled it. Good luck.
four six
506
Hobart, IN
Apr 2, 2007
  • Apr 2, 2007
6qts? wow I gave my installer 3 qts of royal purple
RandyStinchcomb
1,159
Randallstown, Md
Apr 2, 2007
  • Apr 2, 2007
wth a girdle it will hold more fluid but not that much more, you need to check the oil level at the fill plug on the left side of the housing, not on the girdle
G
GettinThere
553
Central Texas
Apr 2, 2007
  • Apr 2, 2007
Randy, is it possible diff fluid is leaking into his axle tubes?
RandyStinchcomb
1,159
Randallstown, Md
Apr 2, 2007
  • Apr 2, 2007
well the fluid does circulate into the axle tubes wth the standard fill level to lube the axle bearings but he's prob filled up both tubes
G
GettinThere
553
Central Texas
Apr 2, 2007
  • Apr 2, 2007
I didn't know that, thanks.
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
D
99 Mustang GT fuel pump issue
  • Darkdayz81
  • Jul 4, 2022
2K
1996 - 2004 SN95 Mustang -General/Talk- Sep 18, 2022
My Copilot Zip
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
8.8 Axle Gear Oil and Modifier Question
  • Red50Fox
  • May 18, 2020
17K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 19, 2020
96pushrod
