Distributor gear removal
  • Thread starter Thread starter PrimerdFury
  • Start date Start date Jul 20, 2004
PrimerdFury
139
Fountain Hills, Arizona
Jul 20, 2004
  • Jul 20, 2004
Does anyone know what I'm doing wrong? I'm trying to get the distributor gear and collar off the shaft. I have removed both pins out of the gear and collar but neither will budge. Is there some secret to doing this that I am missing or what? Please help, Thanks.
302efi
273
Sunny Florida
Jul 20, 2004
  • Jul 20, 2004
A press
I had to have a shop do it for me
MadMatt5oh
441
St Paul, MN
Jul 20, 2004
  • Jul 20, 2004
I tapped mine off with one end on a 2 by 4 and used a soft rubber mallet
HISSIN50
34
129
Jul 20, 2004
  • Jul 20, 2004
buddy of mine just did a couple of them. he used a bearing splitter.
W
Walkerhound
  • Jul 20, 2004
Primer, as described earlier, you'll need a bearing puller for the gear. The collar will be sort of stuck due to buildup under it. Use a screwdriver to wedge between the collar and housing(gently) to try to move it down a little, then back up. It'll come free if you work it up and down a little, being careful not to put pressure on the outer edges which will probably break it. The bad news is with the gear. It's soft/brittle and will break/crack easily. When you try to replace it, be absolutely certain that it is aligned with the pin hole in the shaft because turning it after it's that far up the shaft is close to impossible without destroying it. There is a tool made especially for this project, sorry but the link to it escapes me at the moment. Do a seach through Google, you'll most likely find it. If I run across it, I'll post it. I can't swear to how good/bad it works, just stubbled over it one day while performing the same job you're doing. Good luck with it!
The Hound - Larry T.
As stated, I found the tool. The site says the tool removes and installs the gear for about $48. Site is: http://www.sjdiscounttools.com/the415.html
MadMatt5oh
441
St Paul, MN
Jul 20, 2004
  • Jul 20, 2004
I got mine back on perfect haha, but I am an extremely patient man
PrimerdFury
139
Jul 21, 2004
  • Jul 21, 2004
alright awesome....I got them off with a crankshaft dampner puller, c-clamp, vice and a wrench. Now I just have to get them back on...oh well...I guess patience is the key.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Resolved Does anybody recognise this distributor gear?
  • x_man586
  • Jun 4, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
x_man586
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
