distributor leak
  • Thread starter Thread starter 87redgt
  • Start date Start date Sep 16, 2009
87redgt
32
Richmond, CA
Sep 16, 2009
  • Sep 16, 2009
I have an annoying oil leak coming from where I believe to be the distributor. I have come to this conclusion because there is oil puddled up on the front of the block and the is oil puddled in and on top of the distibutor hold down. I just put a new distributor in with a new o-ring. How do I stop the leaking?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 16, 2009
  • Sep 16, 2009
Are you sure its not the lower intake to block gasket(aka Intake End gaskets) behind the Distributor? Thats normally the case.
L
Lawbreaker5.0
543
Texas
Sep 16, 2009
  • Sep 16, 2009
yeah sounds like a lower intake gasket, clean the area and re check.
86turbo
183
Sep 17, 2009
  • Sep 17, 2009
If it's the intake then this is what I recommend:
Clean up the spot real well and make sure the back isn't leaking also. Get your engine hot and retorque your intake to spec using correct pattern.
Now, did you install the intake? What type of end seal did you use? When you start messin around with aftermarket parts, head milling, etc. (especially mix matching stuff) this will affect the gap between the block center ridges and the intake. A lot of time what will happen when using cork is it'll either get blown out/shifted because the intake gap didn't compress it enough OR oil will work it's way past the weak seal for the same reason.. The oil you are seeing is from the crankcase and I'd bet money it leaks worse the more you beat on the car......no? Hopefully retorquing the intake will fix it, if not just replace the gaskets. I've tried sealing up a leaking lower intake gasket using rtv on the outside and it doesn't work, dont waste your time haha.
good luck
Drew
87GT40
59
virginia
Sep 17, 2009
  • Sep 17, 2009
i had the same issue. it was the lower intake gasket. clean it up and run the engine and watch the area. you might have to give it gas to make the pressure go up. if so just pull on the throttle cable from the front.
cobra1540
37
  • Sep 17, 2009
Does your distributor have an o-ring on it?
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Sep 17, 2009
  • Sep 17, 2009
D
Exhaust Difficulty of fixing exhaust leak at manifold
  • dqureshi06
  • Aug 27, 2026
Fox 5.0 Mustang Tech Aug 28, 2026
General karthief
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Clutch pedal to Quadrant lag
  • Potomus Pete
  • Aug 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
