SO I'M TRYING TO ADJUST MY TIMING AND IT WAS SUGGESTED THAT MY DISTRIBUTOR WAS OFF A TOOTH. I MOVED IT TO WHERE THE #1 ON THE DISTRIBUTOR WAS FACING THE #1 CYLINDER . I THEN TRIED TO SET MY TIMING. IT'S JUST NOT RUNNING SMOOTH. ALSO MY TDC MARKS WHERE NOT LINING UP WITH THE POINTER (ABOUT AN 1 3/4" TO THE RIGHT OF THE POINTER). AFTER MOVING THE DISTRIBUTOR THE MARKS WHERE ALOT CLOSER TO LINING UP, BUT HAD TO TIME IT TO 20 DEGREES AFTER TDC. TO GET IT TO RUN HALFWAY DECENT. SO NOW I DON'T KNOW IF MY DISTRIBUTOR WAS EVER OFF. DOES ANYONE KNOW HOW TO SET THE DISTRIBUTOR SO THAT THERE IS NO ? WHETHER IT IS ON THE RIGHT TOOTH?
