Distributor recommendations
  • Thread starter Thread starter afterglow
  • Start date Start date Feb 4, 2007
A
afterglow
89
  • Feb 4, 2007
I'm finishing the restoration of my '69 Mach 1. It'll have a 351W with a Weiand Stealth intake, Holley Street Avenger 670cfm carb, Comp Cams 262H cam, Hooker longtube headers, Magnaflow exhaust and 3.8 rearend.
I'm starting to get the parts together for the ignition system. I'll probably go with an MSD 6A box and a Blaster2 coil. Should I stick with an MSD dizzy?? Or perhaps go with Crane or Mallory?? Vacuum or mechanical advance??
The car will strictly be a weekend street car.
F
fast4cheap
82
north carolina
Feb 4, 2007
  • Feb 4, 2007
I use a stock duraspark, its the same thing basically as the MSD dizzy, only cheaper, It works on my 68 bracket reacer and my daily driver, In conjunction with a MSD box you got one heck of a Igntion system.
bnickel
5,640
lubbock, texas
Feb 4, 2007
  • Feb 4, 2007
i'd say it really depends on what RPM you turn the motor. less than 6 grand and a re-curved duraspark would be fine. MSD, Mallory and Crane all make really nice E-curve dizzies though that are so easy to tune it's almost ridiculous. basically it comes down to personal choice.
D
D.Hearne
11,730
south louisiana
Feb 4, 2007
  • Feb 4, 2007
Points distributor, Pertronix unit (or any other conversion module) small to large cap adapter and post type cap, Ford racing 9mm wires, hot coil of choice. Good up to 7500 rpms. Way cheaper than going with an all out MSD system.
F
fast4cheap
82
north carolina
Feb 4, 2007
  • Feb 4, 2007
duraspark will turn more than 6 grand, I turn mine 8 grand. It uses the same magnetic pickup as a msd. stay away from the mallory unispark, it sucks.
bnickel
5,640
lubbock, texas
Feb 4, 2007
  • Feb 4, 2007
that's a good setup too, i have pretty close to the same thing. stock points dizzy, mallory unilite conversion, MSD blaster coil, accell 8mm wires, stock small cap dizzy with brass contacts.
bnickel
5,640
lubbock, texas
Feb 4, 2007
  • Feb 4, 2007
not saying the duraspark won't work at all turning that high but spark scatter becomes more of a problem over 6k not because of the pickup but because of teh dizzy housing using one bushing. the MSD units usually use at least 2 bushings if not bearings and don't have the spark scatter problem. not even all duraspark dizzies will have the problem but you can't tell which will and which won't
F
fast4cheap
82
north carolina
Feb 4, 2007
  • Feb 4, 2007
I got what your saying, I just recomended the duraspark unit cause its affordable and it works, I found this out only after having bad problems with a mallory, so installed the duraspark in a pinch, Its never been replaced since.
bnickel
5,640
lubbock, texas
Feb 4, 2007
  • Feb 4, 2007
in his application i'm sure the duraspark will be fine but other people will likely read this thread too and may have a need for the higher revving capability of an aftermarket unit.
A
afterglow
89
#10
  • Feb 4, 2007
  • #10
Looks like I'll try using it with my current Duraspark dizzy then and see how it goes.
How does the MSD box hook up to the Duraspark?? I was reading the MSD 6A instructions and it says I need a certain cable (MSD8860).....
RGS0907
429
New Jersey
Feb 25, 2007
#11
  • Feb 25, 2007
  • #11
New Dizzy
Why does the uni-lite suck? I'm looking for a new one with ajustable advance curves.
bnickel
5,640
lubbock, texas
Feb 25, 2007
#12
  • Feb 25, 2007
  • #12
i've been running a uni-lite for years with no real problems. i did have a problem back in the early 90's with some bad modules but that was apparently because of a bad batch from the factory, once they got that straightened out i haven't had a problem with mine since then
Pbum5
515
Minneapolis, MN
Feb 25, 2007
#13
  • Feb 25, 2007
  • #13
Same thing with My Unilite. Had a problem in the early 90's with the module, replaced it and no problems since.
My car sat for a long time but has always fired right up and I havent even changed the plugs yet.
RGS0907
429
New Jersey
Feb 25, 2007
#14
  • Feb 25, 2007
  • #14
unilite vs Magnet
Mallory also sells the magnetic pickup dizzys too, I was curious if one was better than the other
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Feb 25, 2007
#15
  • Feb 25, 2007
  • #15
I would get the 6AL box, it gives you a rev limiter. Its just a nice safety feature... you know... just in case =)
HookandLadder
261
St Louis
Feb 26, 2007
#16
  • Feb 26, 2007
  • #16
MSD drop in and go. It will hook right up with what you already have and it's easier to curve to your engine. Only thing to add is to get the MSD distributor hold down. Much better piece than the ford stuff.
Cam selection for 92 5.0
  • 48F1
  • Feb 20, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 21, 2022
General karthief
Engine Thinking About 351, Need Some Help
  • derekleee
  • Oct 10, 2016
3K
Fox 5.0 Mustang Tech Oct 11, 2016
derekleee
Engine 78 Mustang Ii Engine Swap
  • 78mIIman
  • Dec 19, 2016
14K
1974 - 1978 Mustang II Talk & Tech Mar 21, 2017
RaggedGT
T
Fox No Boost And Stumped
  • TWEECD
  • Aug 12, 2017
  • 2 3 4
13K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2017
TWEECD
T
A
92 Gt W/351w Advice Needed
  • adumb
  • Sep 24, 2015
  • 6 7 8
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 31, 2015
adumb
A
