- Jan 9, 2008
- 36
- 0
- 0
I've looked into doing my own twin turbo setup, but not sure what else I need.
So my plan is to use two 57mm turbos, will be using flexibale steel tubing 2-3 in, not sure. So I would also need a blow off valve and Im not sure where to go after that, as far as fuel/air mixture and anything else.I wont be using the regular turbo manifold setup, so I wont need any different headers. What can of gains can I expect, will my car/transmission support this kind of power? Any help would be great.
MODS: 2000 Mustang GT(Auto)
-rear Monroe senstracs, H&R supersport
-QA1 12 way front struts, H&R supersport
-Underdrive pullies
-Cold air Intake
-Trick flow intake plenum
-ford racing intake manifold
-SLP long tube headers
-SLP x-pipe no cats
-SLP loudmouth exhaust
-Diablosport predator tuned
-Underdrive pullies
-Cold air Intake
-SLP x-pipe no cats
If you want more info on building turbo setups checkout the following links:
