how the hell do you remove the dizzy bolt. its 13mm...and i cant get any ratchet/wrench on it at all...what does everyone else use? I'm getting very frustrated...
You can get 1/2" drive tools in there? I guess the 1/4" drive stuff is underkill.Green 94 5.0 said:im telling you.....a 1/2" drive 1/2 12pt swivel socket with an extension.....you dont need anything else.![]()
HISSIN50 said:A 1/4" short socket, with a 1/4" swivel joint, and then two 1/4" extensions work all right for me. I should get one of those wrenches.
If you picture the open end of a box wrench. Cut the wrench off below the head. Now put a square receptacle for a ratchet wrench in the nub just below the head.1994Vib.RedGT said:what the hell is a crows foot?
i couldn't even get a wrench on it, it is so cramped. the crows foot makes it easy to get a wrench on it.1994Vib.RedGT said:Im not sure how that would help get the EGR nut off though, last time I took that thing off it was a PITA, I had to heat it up with a torch for like 20 minutes
