T twstd50 Member Oct 20, 2003 97 0 6 Jul 12, 2004 #1 Jul 12, 2004 #1 Do 15x5 Weld Prostars fit up front on a 94 without spacers and or grinding the edges of the front calipers??? I'll be getting some soon and wanted to know what to expect. Thanks...
95snoozer Active Member Dec 14, 2002 2,572 1 48 RCR Jul 12, 2004 #2 Jul 12, 2004 #2 you need to grind reguardless how much you grind determines the spacer size
swingline New Member Sep 18, 2003 1,252 0 0 TCB - Taking Care of Business Jul 12, 2004 #4 Jul 12, 2004 #4 Ask Stangfreak95 (Mario). He is running the same wheels I think.
95snoozer Active Member Dec 14, 2002 2,572 1 48 RCR Jul 12, 2004 #5 Jul 12, 2004 #5 you need to grind reguardless how much you grind determines the spacer size
95snoozer Active Member Dec 14, 2002 2,572 1 48 RCR Jul 12, 2004 #6 Jul 12, 2004 #6 my skinnies took a 716 spacer and some grinding of the crossbar for a 5/16 it takes the bar being ground off and some grinding of the face of the caliper and for no spacer it takes mucho mucho grinding
