- Aug 7, 2008
- 97
- 0
- 6
Gonna be installing a set of Polished/ported GT 40 heads with stainless valves, and explorer/gt 40 intake and a E303 cam. Plan on using unequal length header with X pipe and Flow master catback.
Will also be installing 65mm throttle body to match intake. Have not changed MAF and was not planning on it unless absolutely necessary after install of the rest of the parts.
Will I require larger injectors for this setup? Will the stock 70 mm MAF work with the FMS 65mm throttle body I intend on installing to feed the intake?
Any help is much appreciated...
