Do I need a tune?
Fivespeed
Just finished a H/C/I swap on my '93 5.0 5 spd.
-AFR 165 heads w/ Comp Cams springs
-Jay Allen Custom grind cam
-Holley Systemax 2
-Comp Cams lifters/pushrods/ 1.6 RR's
-BBK 70mm TB/70mm EGR Spacer/75mm MAF/BBK CAI
-BBK Fuel pres. regulator
-MSD 6AL/wires
The car is currently set a little more advanced then base timing and it runs fine, etc. However it honestly doesn't feel much if at all faster than before the h/c/i swap. The car does still have the stock 2.73's... would gears make that big of a difference? I still have the stock injectors and fuel pump... fuel pressure is around 22-24 lbs.
The whole setup is made for top end as I will be going with a single turbo within the year.. and it does have a little pep above 5k rpm however it's nothing to be amazed about. You guys have any ideas?
First of all your fuel pressure is very very low, try 38-40 psi with the vacuum line off.
The 19# are OK for now, you might have to eventually swap over to bigger injectors and a MAF calibrated for them; and a bigger fuel pump if you go turbo.
Also is you MAF callibrated for the stock 19# injectors? I just have to ask.
And I guess you know that a turbo motor without a turbo isnt going to be all that quick. :) I dont know your secret cam specs, but the car should be quicker than stock.
MAF is calibrated for 19's. I plan on going with bigger injectors and fuel pump during the turbo installation.
It isn't 100% a turbo grind cam, it simply makes power where it should with a turbo in mind ;)
I didn't expect to be blown away with power as my setup isnt 100% complete, however I was definitely expecting more over stock before the turbo kit is installed.
I will raise the fuel pressure and see what happens, thank you!
One thing I have learned from working with Jay is that IF you have a concern about his work/product/design/anything, you should call him first.
Don't think for a second that you are 'bugging' him, or wasting his time.
He lives for helping his customers reach that Happy Place :D
Asking the general public what to do to improve on HIS setup, may even mildly offend him.:(
I suggest calling Jay directly... He will answer ALL of your concerns.
With that said,
He grinds cams for very specific applications. Change anything significant in the combo, and the cam is no longer appropriate.
If you think about it, this is the very reason you went with a custom over an OTS in the first place.
Check over your buildsheet, and compare the specs you gave him to what you have in the car now. What are the differences?
Lack of boost will make a BIG difference...
good luck,
jason
I was on the phone with him for an hour talking about the kind of cam I wanted and the setup it is going with. The entire valve train was ordered directly from Jay with the cam. I couldn't be happier with the customer service Jay has offered!
I'm absolutely not implying the cam has something to do with it... I was figuring it was something "obvious" I didn't check or mess with after the h/c/i swap that is starving me of power.
Jay is a real busy guy and I didn't want to prod at him with "stupid" questions. ;) It's possible this is just how it's going to be until the setup is 100% complete and it really comes alive.
Thank you for the reply!
With that said,
good luck,
jason
I know exactly where you are coming from, but I have been through something very similar to what you are going through, and Jay was very specific.... Call him if there is a concern.
He will make time for you, and your questions.
Jay is the best person to ask about how the car will run before the setup is complete / with out boost. The rest of us will just be guessing.
A couple of questions though...
Fuel pressure - Did you set the pressure with the vac line removed/plugged from the regulator? It should be 38-40psi with the vac line OFF.
How does your intake vac signal compare to your cam spec sheet?
How does your cranking compression compare to your cam spec sheet?
These 2 things can point to issues with the installation....
jason
