I have a 67 with a C4 transmission. Since putting my new motor in I've noticed some odd issues with the tranny. Basically, it is spewing ATF when I park it after a drive. The first time it happened I came outside to see a very large puddle of ATF on the driveway. I remembered the car was running hot on the drive, well above the halfway mark on the temperature gauge. I figured it was temperature related but was still perplexed.
The next chance I got I went ahead and changed the transmission fluid and filter since I hadn't in awhile. However I believe I overfilled it by about a quart so I bled out what was about a quart.
The next day I took it for a somewhat lengthy drive. I had no issues during the drive but when I got home and parked it I noticed a very aggressive internal fluid flow sound. A second later I had ATF pouring out everywhere. I tried to stick my head underneath to see where it was coming from but I couldn't make anything out. I popped the hood and noticed that the transmission dipstick had "popped out" of the dipstick tube. For a second I thought maybe this was the cause but there definitely seemed to be a source on the drivers side.
Next day I again changed the fluid and made sure I had the right amount of ATF. On the next lengthy drive I didn't have any problems but when I got home the same symptoms showed up, only less severe. I didn't hear any fluid flowing and the transmission wasn't spewing everywhere. There was also less fluid on the ground. The only place it was leaking seemed to be on the drivers side near the header collector. I popped the hood again and noticed the dip stick popped up again.
What does this sound like? A blown or weak seal? Seems like it was a seal I would have problems with it while I'm driving.
Oh one other thing I noticed. On the last drive as I was heading home I noticed a fairly strong smell of sulfur. Not really sure what this was, smoking ATF? If it was ATF then it appears it is leaking while driving.
Thanks
Thanks
