Do I need to run an FMU with this setup?
mustang20010
60
I'm in the process of installing my Paxton Novi2000 on my 94 GT, and I'm just wondering whether or not I need to use the supplied FMU. My car is already equipped with an Aeromotive Competition fuel system, 55lb low impedance injectors, and I will be using an Anderson PMS to tune.
So with that setup, is the FMU necessary, or is it kind of redundant? It seems to me like it would be but I'm not sure. Plus installing could be a little bit of work, since it has barbed fittings for rubber hose, but obviously I'm running braided stainless fuel lines. Then again I could probably find some adapter fittings or something and hook it up, but it would be a considerable amount of work. Just wanted to know if I need it with all that other stuff.
Thanks!
Thanks!
You shouldn't need the FMU with those 55#ers. :nice:
i HOPE i'm gonna be making some power! :)
DSS Pro Bullet 306
8.7:1
AFR 185
Holley Systemax
CompCams bumpstick
70mm TB
80mm MAF
Paxton Novi2000 @~14psi
Aeromotive Competition Fuel System
Anderson PMS system
Bassani equal-length shorties
Bassani off road x
Borlas with dumps (soon)
