Everyone always says do it yourself, You'll save money.... pfff
To bad not everyone has that mechanic mentality.
Today i installed only the front struts of my car. Unfortunately i took way too long on this project, just like all my other DIY.
I had to use a stinking propane torch to get the nuts out of the struts. Liquid wrench didn't do anything but make me waste time. Also whats up with the nut on top of the strut? I bent a flat head srew driver twisting that thing. Then i bent the strut itself(old one) where the screwdirver goes to get that bolt out. I ended up have to grind one of them off
. Must be an easier way! It doesn't help that the car has 100,000+ miles on this suspension.
Oh and i tryed to use the internal spring compresser o the fronts, but the piece of junk compresser didn't even fit throught the hole at the bottom of the control arm. How fustrating all this is....
other DIY and time taken
Sony radio+amp+sub - 6 hrs - solo
Interior paint pieces(6)-5 hrs - 2 peeps
magnaflow catback- 10 hrs. - 2 peeps
Pi intake- 2 days - solo
tokico shocks- 1 day so far...- solo
Steeda sport springs- pending the shocks, trying to do it at same time...
I guess i have saved a buck or 2.
. Must be an easier way! It doesn't help that the car has 100,000+ miles on this suspension.Oh and i tryed to use the internal spring compresser o the fronts, but the piece of junk compresser didn't even fit throught the hole at the bottom of the control arm. How fustrating all this is....
The cat back is a bit harder to do than a mid pipe and a bit more time consuming. Have an extra set of hands, some sockets, liquid thread lock and your good to go.
Not here...
