Do they make a kit u can buy to swap aode to t5?
AMP, Stangparts, et al have kits. A search in here will reveal a ton, including peoples' thoughts on the kits vs piece-mealing it or using new parts.
Good luck.
the search is your best friend. i have answered this countless times already. here are a few of the threads i have posted in regarding the subject.
http://forums.stangnet.com/showthread.php?t=562036
http://forums.stangnet.com/showthread.php?t=560746
http://forums.stangnet.com/showthread.php?t=559408
http://forums.stangnet.com/showthread.php?t=459702
and all the pics from my swap can be found here:
http://ridewithdrc.com/roger/mustang/trannyswap
all your questions should be answered in those threads. if not, feel free to PM me with anything else you may need to know and i will be glad to help.
Faster depends on how fast and accurately you can shift. You will spend almost as much on the swap as you would to get a built trans and converter. Don't get me wrong, I like 5spd's. The question is would I convert a car. I think I'd just buy it the way I wanted in the first place. An auto trans with a shift kit and good converter is easier to drive and race than a stick. Auto's do eat about 5%-8% of your power over a stick, but if the shift points are set properly you can still beat someone with equal mods that doesn't shift at the proper time. Does a stick feel faster, yes. So put 4:10's gears in and your auto will feel fast too.
That's my point exactly. If your buddies shift too quick, a common problem, an auto with pedal to the metal will win. Most of the time 5spd's just "feel" quicker off the line. The difference is about 20-30HP sucked up in the trans. The difference can be tuning or that they just really suck at shifting. If you don't have a shift kit get one. Also, 3:73 or 4:10 gears. After that you may not want to part with your slush box. FYI, power breaking an auto at the line is a lot easier than dumping/smoking a stock clutch at the line. :flame:
interex1982 said:
they dont seem to be that much faster.
Yes, with the same engine and an experienced driver in the 1/4 mile they can be about a 1/2 second or more faster. An inexperienced driver can smoke the clutch, burn the tires, shift too early, too late, or too slow missing the power band. Then you have him :nice:
why is the harness needed?
if you use an auto eec/harness,will the reverse and nuetral lights still work?
also,I have a chip tuner tweecer.
Im going to just fix it up to a 5spd binery.
but whats this harness about? would i still need one?
