Do you need to change valve springs for stage one modmax cams
As long as the lift is about stock then the stock springs should work fine. You need aftermarket springs when you increase the lift above stock, and that is prety much it. Maybe if teh cam had a radical lobe on it springs might be needed, but I doubt stage 1 cams would be like that.
