Do you think this combo will have piston to valve problems?
skiwesser
35
First off I will check it out, but want to know what you guy's think.
.030 bored stock block with flattops, comp XE264HR (.544 lift w/1.7's, 212/218 @ .050 114* lsa). With E7's milled .035"
Think I'll have piston-to-valve issues?
What about springs? I know stock wont work but can I get a spring that will allow that much lift on E7's?
Duration is closest at 10 BTDC, It also depends on your flat top as far as relief depth etc, you shouldn't run into any radial clearance issues with the small valve E7.
