does a 5.0 have an oil deflector??
1fastsn95
122
Carthage, tn
My engine builder says Im suppose to have an oil deflector. i cant find one in my "pile o' parts" from my old motor. But, when I was dissassembling the old motor, I busted the timing cover and scrapped it. Dont think there was one attached to it :shrug: and one other thing, my engine builder is a GM mechanic by trade, but has built some SB fords. So is he wrong? Help me out here. Thanks!!
Not that i'm aware of. The harmonic balancer bolts to the crank and the seal rides against that. The timing cover may have a small deflector plate but that's it. I can't quite picture what else it could be.
He is not referring to any of those things.
You are referring to what is often called an "oil slinger". It goes on the end of the crankshaft, in front of the crank gear and behind the timing chain cover.
It looks like this:
It's purpose was to keep oil from splashing directly on the timing chain cover seal, and also to "sling" oil back on to the timing chain/gears and/or fuel pump eccentric (if equipped with a mechanical fuel pump).
yeh Im sure thats what were talking about. So as long as Im runnin a Electric fuel pump I dont have to have it right? My timing cover is from an 83 model but I have a block off plate there where the mech fuel pump went. That shouldnt matter right? Thanks guys!
