Borderline Tech...but maybe opinionated...so
Do the new Catted X and H pipes from LMR/AM still require smog? Or does it cause the cats to prematurely fail without it?
Looking at all the kits with the exception of the weld in SVE w/Flowmasters high flow cats , all have the provision for it.
I recall reading @MFE92 used magnaflow magnetic spun high flows, but didn’t see any others except yeah you can but no comment on the smell.
Second question, someone mentioned just venting the air provision to atmosphere via a check valve would help the longdvity of cats? ( This seems counterintuitive to me I don’t know why).
Lastly can you just run the air pump striaght to the provision port without the TAD/TAB stuff (mine was lost in the fire) and it moreless do the same job? Pretty in this scenario its all or nothing.
Trying to make my Foxbody smell a little better. In the process of getting a new shifter (old one is torn), Charcoal Canister and purge solenoid.
Started to look at my old pipes/ turn downs and figured it may be time to change up things.
