Ok, here i go again. This is the third time in about 4 months that my car (95 5.0) has killed, and will crank but not start.
The first time this happened i changed the PIP in the distributor, and the car did not start right up. It took about an hour of cranking it over and it finally started and ran great for a few weeks.
The second time this happened i let the car sit for about a week. When i deceided to start working on it, it cranked right up. Now it finally killed again.
This is what happened yesterday: When i started it, it idled fine for a few seconds, and then it killed. (My first indication that something was not right). I restarted the car and drove for about a block and it made a pop sound a few times then it killed. I restarted the car and drove into a parking lot where it killed again, and would not restart.
The only modifications that i have are x pipe-mufflers, and i removed the smog pump.
When i try to start the car it cranks over fine. I do not hear the fuel pump prime. I just hear the CCRM click a few times. I changed the fuel pump months ago. I also got another CCRM from the junkyard yesterday, and the car does the same thing.
I do not have voltage at the coil. I have not checked for voltage at the infectors this time, (last time this happened to me i did not have voltage at the injectors). The fuel pump is not priming, so i do not have fuel pressure.
I had the TFI check today. Once again it tested good. (Yes, it was tested until it was hot)
Last time this happened i tried another coil, but it still did not work. (There is no power at the coil, so its pretty obivious that it would not work but i was willing to try anything.
Any other ideas/Suggestions????
Thanks,
jeff
Thanks,
jeff
