Doing the one wheel peel...
  • Thread starter Thread starter grey5.0beast
  • Start date Start date Jun 12, 2007
  • 3
1 of 3 Next Last
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
Jun 12, 2007
  • Jun 12, 2007
OK so I have been doing the one wheel peel on and off(sometimes it hooks,mostly its a no go) and I'm gettin tired of pullin out of a place hard with only one wheel going upin smoke
So this is pretty much what I need then right?
http://cgi.ebay.com/ebaymotors/1986...tegoryZ33731QQihZ004QQitemZ140126657275QQrdZ1
I'll be doing it myself, I did the gears by myself(along with everything done to mycar) so I am sure this is gonna be somewhat of a cake walk.
I will be going by a guide I have bookmarked on my other computer.
When I did the gears I swapped out all of my bearings in the housing soI should be good there. Anyway,any tips are appreciated.
BTW I was doing the one wheel peel most of the time at the track so maybe now I'll be able to beat my 2.25 60' and hit 13s...
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jun 12, 2007
  • Jun 12, 2007
My 86 did it, my 93 does it now (@ 64k miles )
That looked like a shim kit to me but I could be wrong. When I get my gears in I'm replacing EVERY bearing.
grey5.0beast
Aug 3, 2004
atl ga
Jun 12, 2007
  • Jun 12, 2007
yeah I did that, but those are friction discs and shims, like little clutches, they wear out.
The discs and shims are in a sequence.
jhonda
125
Huntersville NC
Jun 12, 2007
  • Jun 12, 2007
You will need rubber or latex gloves and rags<--lots of each
grey5.0beast
Aug 3, 2004
atl ga
Jun 13, 2007
  • Jun 13, 2007
lol yup,used to that
N
niklid05
140
Kutztown PA 19530
Jun 13, 2007
  • Jun 13, 2007
screw rubber gloves. Youre not a real car enthusiast unless the harmful chemicals soak into your pores.
Mustang78
486
Aberdeen, WA
Jun 13, 2007
  • Jun 13, 2007
+1!! i rebuild my trac loc with a kit from northwest differential, it was 50 bucks and had the extra friction plate too. Straight forward install, when the diff is back together test fit the big pin in the middle for fitment, i had to grind the 2 flat spots all the way down the pin..and i also had to remove the "shim" behind each of the spider gears..
~Mark~
Mustang78
486
Aberdeen, WA
Jun 13, 2007
  • Jun 13, 2007
~Mark~
Mustang78
486
Aberdeen, WA
Jun 13, 2007
  • Jun 13, 2007
**** i thought i clicked edit
stykthyn
5,232
2,652
223
gainesville
Jun 13, 2007
#10
  • Jun 13, 2007
  • #10
it's a sign from god
Mustang78
486
Aberdeen, WA
Jun 13, 2007
#11
  • Jun 13, 2007
  • #11
that i need to "edit" my life?? lets see here...click, drag, trash..delete, edit, copy&paste.. Thanks GOD!!
C
crumbie50
#12
  • Jun 13, 2007
  • #12
~Mark~
dang I was wondering about that....
just rebuilt my traclok and added a thicker shim. had to beat the gears back into the differential and that pin is tight, too! had to beat that sucker in also. If I ever get the pin all the way in, I doubt I'll have a problem with one wheel peel. LOL.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Jun 13, 2007
#13
  • Jun 13, 2007
  • #13
Oooooooh...
*light bulb*
D
Deleted member 87397
Jun 13, 2007
#14
  • Jun 13, 2007
  • #14
I think I swa someone on here that recently redid theirs, but used a modified disc/shim sequence that was just supposed to be awesome, but I don't recall who it was. Anyone know what I'm talking about?
grey5.0beast
Aug 3, 2004
atl ga
Jun 13, 2007
#15
  • Jun 13, 2007
  • #15
yeah the writeup I have has the modified sequence and the stock, I don'tknow the benefits of one over the other.
D
Jun 13, 2007
#16
  • Jun 13, 2007
  • #16
Hey hook me up with the link when you get a minute. I want to try the modified sequence when mine craps out on me. 21 years old and the original trac loc still works like a dream, but for how much longer is anyones guess
grey5.0beast
Aug 3, 2004
atl ga
Jun 13, 2007
#17
  • Jun 13, 2007
  • #17
You better knock on wood lol, cuz that's how I wasuntil I started doing a bunch of second gear clutch drop burnouts
Here you go
http://www.angelfire.com/theforce/5ohcpa/cpa5ohtech001.htm
M
MustangOwner
Banned
Dec 13, 2006
160
#18
  • Jun 13, 2007
  • #18
Depending if its worn or not... you also might need a 8.8" Traction-Lok "S" spring. Sometimes you need it and sometimes you don't. But for 18.00 bucks you miswell just put a new one in!
D
Jun 13, 2007
#19
  • Jun 13, 2007
  • #19
Good tip. Thanks for the advice. I may end up re-doing the entire rear end since I want to put down mad power eventually. I'm thinking......
Rear disc conversion
Auburn posi
31 spline axles etc.
Not sure what I'll do yet. Yo Beast, why are you doing 2nd gear clutch dumps anyway? I think you were trying to kill the trac lock just so you could have something else to do to your car.
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jun 13, 2007
#20
  • Jun 13, 2007
  • #20
ya know, my has almost 180K on it now and the 8.8 in that thing still wont spin only one tire, the 90 vert spins single trac sometimes, but the 86 has never only spun one tire, huuurrrmmm, it might has some mod work done to it, Must investigate!!!
  • 3
1 of 3 Next Last
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 14, 2026
Rdub6
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
