DONT KNOW WHATS CAUSING IT
  • Thread starter Thread starter THUMPER306
  • Start date Start date Feb 15, 2009
THUMPER306
11
BROWNSVILLE,TX
Feb 15, 2009
  • Feb 15, 2009
90 GT W/306,MILD PORTED GT40 IRON HEADS,E-303 CAM ,EDELBROCK PERFORMER 5.0 INTAKE ,65MM TB,C&L INTAKE PIPE W/76MM MAF,24LBS INJECTORS,ADJ FUEL REGULATOR SET TO 40LBS,1 5/8 HEADERS,4.10'S ON 275/R4017'S.
THE CARS DRIVES AND PULLS GREAT BUT BOGS BETWEEN SHIFTS.I HAVE NO CLUE ON WHAT CAN BE CAUSING THIS.IT FEELS LIKE IF THE ECU RETARDS TIMING OR SUMTHING.THIS IS ONLY AT WOT FULL LOAD. THX FOR UR HELP.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 15, 2009
  • Feb 15, 2009
have you tried to pull the codes? hold on i will find the list that tells you how to.
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 15, 2009
  • Feb 15, 2009
http://forums.stangnet.com/698148-help-me-create-surging-idle-checklist.html
THUMPER306
11
BROWNSVILLE,TX
Feb 16, 2009
  • Feb 16, 2009
I TRIED PULLING OUT THE CODES,BUT IT DIDNT WORK THE TEST LIGHT JUST STAYS ON.MAY BE IM DOING SUMTHING WRONG
90topdown
138
Philadelphia, PA
Feb 16, 2009
  • Feb 16, 2009
Has the ECU ever been reprogrammed for the 24 lb injectors??
Stock ECU's are programmed for 19lb injectors.
If you are running 24's on it, that could be your problem.
THUMPER306
11
BROWNSVILLE,TX
Feb 16, 2009
  • Feb 16, 2009
IT HAS A 76MM C&L MAF W/24LBS CALIBRATION TUBE ON IT. I'VE HAD THIS SET UP FOR SOME TIME ALREADY AND IT WORKED FINE UNTIL NOW THAT IS BOGING BAD.
Need Help, Car Wont Start, I've Gone Through Both Checklists
  • 93silverlx50
  • Jul 22, 2017
  • 2 3
13K
Fox 5.0 Mustang Tech Apr 30, 2019
General karthief
  • Locked
SC 1994 GT Super Fast!!!!!
  • Red1990Lx
  • Feb 13, 2011
2K
SN95 Mustangs For Sale (1994-04) Feb 24, 2011
Red1990Lx
Click here for a laugh...
  • 1991notchbackLX
  • May 30, 2009
  • 3 4 5
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 2, 2009
strtrcr50
