SC 1994 GT Super Fast!!!!!
Red1990Lx
79
Ohio
Trying to get a jump on the Spring. I have had this car since 2007 and have barely put 500 miles on it. I am going in a different direction and am trying to get things going. Nothing wrong with the car, very fast very easy to drive. I am tring to get $9,500 for it but am open to offers as well. Please no thread jacking or anything like that... [email protected]
Basic Info:
1994 laser red tinted clearcoat Mustang GT
~75k miles on the body, 9K on new motor
Rear window and quarter windows tinted
Suspension
GW Rear lower control arms
800# f springs (linear)
180# rear springs (linear)
Energy Suspension Urethane front sway bar mounts
Koni Double Adjustable (yellow) shocks & struts
Max Motorsports camber/caster plates
Grigg's Bumpsteer kit
Urethane spring isolators
Chassis
GW subframe connectors
Steeda Front Strut Tower Brace (not installed)
Solid steering shaft
Aluminum rack bushings
Konig Villain 17x9" wheels
Kumho Ecsta SPT tires 275/50/17
Front Brakes
Brembo 4-piston calipers
13" cross-drilled rotors, zinc washed
Goodridge Stainless Lines
Speedbleeders
Hawk HPS pads
Rear Brakes
Hawk HPS pads
Cross-drilled rotors
Speedbleeders
Engine
Engine bored .030" over, 306 cid
Magnafluxed/Blueprinted block
Balanced rotating assembly
Crank oil holes chamfered
Probe SRS Forged pistons, ~8.5:1 compression ratio
Ductile iron piston rings w/Chrome scrapers
Forged H-Bean connecting rods
Sportsman crankshaft damper
TFS Stage 1 cam
Stud-mount 1.60 roller rockers
Edelbrock 6061 Heads
3-angle valve job, 1.92" intake, 1.60" exhaust valves
New roller lifters
Trick Flow chromemoly pushrods
MSD distributor cap
Crane HI-6 Ignition system w/coil
JP Performance timing chain/sprockets
NGK Spark Plugs (2 ranges colder)
Cobra rocker covers
FMS head gaskets
Felpro engine gaskets
Fresh bearings (all)
ARP screws/bolts
Mobil 1 10w-30 fully synthetic after proper break-in
Fuel
42 lb/hr injectors (Ford)
Aeromotive adjustable fuel pressure regulator (newest version)
255 in-tank Walboro fuel pump
Vortech T-Rex fuel pump
Intake
FMS Cobra intake manifold
FMS 65mm throttle body
Supercharger
Vortech S-trim
Smaller pulley, 15psi boost
Rebuilt supercharger, fresh bearings & seals
AFM 4" power pipe
Pro-M 80mm MAF
Cooling
Fluidyne 3-core radiator
Earl's stacked plate oil cooler
180-deg thermostatic oil filter adapter
196-deg thermostat
Stewart high-flow water pump
70/30 mix of water/coolant w/water wetter
Exhaust
Mac equal length shorty headers 1-5/8"
Bassani Stainless x-pipe w/high flow cats
Borla Stainless Mufflers
MAC SS tailpipes
Driveline
Mcleod clutch w/custom blueprinted pressure plate
Firewall clutch cable adjuster
3-position clutch quadrant
Adjustable cable
Pro-5.0 short throw shifter w/Steeda tri-ax shift handle
Aluminum ball shift knob
Redline synthetic diff gear oil
Mobil 1 synthetic tranny fluid
FMS 3.55 rear diff gear
Interior
Autometer Fuel Pressure/Boost/Oil Pressure/oil Temp/Water Temp Gauges
Kenwood Stereo
Pioneer 3-way speakers (front/rear)
Sony 1000w amp
Alpine 150w amp (for subwoofer)
12" JLW3 JL Audio subwoofer (not installed but included)
Alarm w/pager
New A/C condenser & drier
Bullitt pedals
http://i1225.photobucket.com/albums/...6/IMG_0007.jpg
http://i1225.photobucket.com/albums/...6/IMG_0006.jpg
http://i1225.photobucket.com/albums/...6/IMG_0005.jpg
http://i1225.photobucket.com/albums/...6/IMG_0004.jpg
http://i1225.photobucket.com/albums/...6/IMG_0003.jpg
http://i1225.photobucket.com/albums/...6/IMG_0002.jpg
http://i1225.photobucket.com/albums/...6/IMG_0001.jpg
