Door Jamb ID Code
  • Thread starter Thread starter No.11
  • Start date Start date Apr 2, 2010
No.11
614
10
48
Los Angeles
Apr 2, 2010
  • Apr 2, 2010
An article by AmericanMuscle says that you can find what transmission came with your car by checking the door jamb sticker. It says:
AmericanMuscle.com said:
If you have a 6 as your first digit, you have five-speed manual, T-45 OD Mustang Transmission. This is the standard Mustang transmission that is found in 1996 to Mid 2001 Mustang GTs as well as 1996 to 1998 Mustang Cobras. If you have a 5 as your first digit, your car came with a T-5 OD Mustang transmission. Finally, if you have a K as the first digit in the "TR" code, you have a TR-3650. This Mustang Transmission is found in mid-2001 to 2004 Mustang GT, the 2003 and 2004 Mach1 and the 2001 Cobra. The 2005-2007 manual Mustang GT's also a T-3650.
But my code in the TR section is TRRBB... which doesn't match anything else I've seen. Does anybody know what each of them means? I know the first one, T, must be the transmission, and the other 4 are the springs, but what exactly do they mean? Thanks in advance.
Saleen0679
876
24
49
Yakima, WA
Apr 2, 2010
  • Apr 2, 2010
The first pair of codes are for the front L/R springs and the second pair are for the back L/R. If you had the information for your make/model you would be able to cross the specific code to a part number and probably the spring rate for each spring.
No.11
614
10
48
Los Angeles
Apr 2, 2010
  • Apr 2, 2010
So according to the first digit, T, what trans do I have? I know I should have a 199 t-5 world class t5 but just want to know for sure what it means there.
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Apr 11, 2010
  • Apr 11, 2010
T = AOD
RR = front springs
BB = rear springs
What the springs codes decode to depends on the model year.
Mustang5L5
Mod Dude
Feb 18, 2001
43,376
18,123
224
Massachusetts
Apr 11, 2010
  • Apr 11, 2010
Means your car originally had an AOD from the factory.
There are really only two choices for the trans..either an AOD, or a T-5. All the other trans came after 1995. I assume this is a Fox we are talking about here right? You have a T-5...but apparently someone put it in there after Ford stuck an AOD in the car
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
P
Interior and Upholstery Door Speakers- found suggestion to go component, not coaxial
  • pindude80
  • Apr 21, 2025
2K
Fox 5.0 Mustang Tech Apr 28, 2025
Mindseye007
