I have 600 cfm DP (model no.4777) on a mild cam 302 engine, Weiand dual plane manifold, MSD 6T ignition and duraspark II distributor. I am having a problem to properly tune the carb. I can start the engine only with rich settings and choke making huge amount of white smoke filling garage for 2 cars withing a few seconds. Idle mixture screws are 1 3/4 turn out, the engine stumbles at a leaner mixture at no throttle or WOT. Fuel is set to lower 1/3 of the adjusting nut, even at this level fuel still leaks through the sight plug. But fuel level set higher than 1/2 causes that a stream of fuel appears at a venting tube on the top of the carb. Timing is set at TDC with the engine off, so far could not measure timing at idle. The distributor picks vacuum from timed spark port. What am I doing wrong? Is this carb broken or too large for the engine?
