Listed is a 3" x 3" Dr. Gas Exhaust Crossover kit with Summit header collector, I intended to use this on a 1966 Ford Mustang (with headers). This should work on most 64.5-73 V8 Mustangs. actually since it is a cut and weld to fit solution it should fit most applications using a 3" X-pipe or H-pipe for a dual exhaust system.
Asking $200
I think this is a good deal for high performance exhaust components (compare with places like Mustangs Plus and you will see!). I do prefer local pickup but can arrange shipment. These are located in Northern Virginia (22152 Zip Code).
Included are the following:
1964.5-1973 Mustang 3" x 3" Dr. Gas Exhaust Crossover Kit:
3" inlets, 3" outlets. This is a 5-piece kit is a cut and weld to fit. The bends are mandrel bent to maint flow without kinks.
"Dyno testing of the Dr. Gas Crossover shows a 1% to 5% gain in both torque and horsepower at all engine speeds over open headers"
Summit Racing header collectors: (3" x 3") Qty 2 (1 pair)
I have exhaust parts listed as well. Let me know if you need any other Mustang parts!
Images are of actual items listed.
Asking $200
