Drag Lites on the front of 2000GT
forpit2000gt said:
what offset are you running on the front wheels with Drag Lites?
There was only one offset for my 4" on Jeggs.com. Here is the description
Part # 927-90-54342
Size: 15 x 4
Rear Spacing: 2.25''
Bolt Circle: 5 x 4.5''/4.75''
Price $122.00 each
The main things you need to get is the 7/16 spacers for the fronts.. With those you can now clear the brake caliper
Part #720-2372
Description- Wheel Spacer, 7/16'' Thick, Fits 4.5''-5'', 5-Lug Bolt Pattern Price $12.99
I would recommend new wheel studs, because by adding that spacer you loose alot of threads...
ARP Front Studs
Part #070-100-7703
Description- .625'' Knurl; 1/2''-20 press-in stud features a .625'' knurl, will fit most disc brake Fords front and rear, and Chrysler front brake applications. 3'' long.
Price $9.99
Also you will need new lugnuts and you might as well make em pretty
Mccard Lugnuts, closed ended and fits perfect with the new rims, and wheel studs
Part # 671-63014
Description -TOUGH NUTS X/LNG 1/2'' CTR
Price $14.99
forpit2000gt said:
I should have been a little clearer. I want 15x7 on 5 lug. I know about the spacer. I already have lug nuts and will get studs when I find the wheel that will work. Thanks. :D
with a 15x7 front wheel I don't actually know.. I have seen that combination before on this board, hopefully somebody with that setup chimes in.. untill then.. bump!!
