Street tires are not made to be heated up. They actually grip less when heated.
With a street tire you should drive around the water box, no burn out, and stage.
Drag Radials, water box and burn out. Same with slicks. The guy who sits there and does a big smoke show for about 10-15 seconds is just having fun, wearing out his tires, and doing it for show. All the experienced racers at the track I go to, do a 5 second burnout and stage. As in the Nitto information I posted previously,
Nittto drag radials perform best at 110 degrees, which really is not hot on a summers day. One race day, I went through the water box, ripped the tires, moved up to lin-lok and burn out and then there was a delay, debris on the track. I sat about 5 minutes. I have a 5 speed and do my burn outs in 2nd gear. When I dumped the clutch, the tires spun a little, the engine bogged and stalled. So I did my burn out again in 1st. gear and it started bogging right away, so I let go off the lin-lok and rolled out of it. I thought was just going to spin because I didn't do a lengthy burn out. Just the opposite, hooked great 1.9 60' time. It was my second time trial so the tires really didn't require a second hard burn out, just a light one. I had already did a hard burn out in my first time trial.
Read this below from Mickey Thompson Tires
DRAG SLICK COMPOUND, ROLLOUT, AND BURNOUT SPECIFICATION SHEET
BURNOUTS- FOR MOST APPLICATIONS
1. First pass of the day hard burnout. After that follow general guidelines of #2 and #3 stated below.
2. Automatic transmissions and Softer compounds: First pass or two, fairly hard burnout, after that a light burnout should be sufficient.
3. Standard transmission "Stockers": No burnout or short, dry burnout. Super Stock and Comp cars- light burnout, haze tires and stage immediately.
