drag struts
myslo50
247
ohio
question is what do u guys think of running motorsport b springs and 90/10 drag struts?
this is the set up i am getting ready to do--
95 spindles
motorsport b lowering springs
moser 28 spline 5 lug axles (just picked them up last thurs)
95 tri bar 17x8 rims (temporary for now)(need to get rid of my 4 lug r's)
93 cobra rack n pinion
still have to get some odds and end things to buttion up the conversion.
i get my house next month, so im gonna start the conversion in my new heated garage
That's a mismatch. Which do you want, street handling or drag? The 90/10's aren't that good for street, although I'm sure someone is using them. I'd suggest getting adjustable shock/struts, that way you can have both worlds. Tighten them up for everyday handling then loosen the front for the drags. The adjustables on full loose are the equivalent of 70/30's. If you go with that original combo, it won't ride/act the way you want.
i actually forgot about the adjustable struts ill just put a set of thoes on. i also plan on putting a lightning 351w in also but that will be for this winter. i wonder how a 351, b-springs and longtubes will look?
