draining brake lines?
  • Thread starter Thread starter paintballtommy
  • Start date Start date Mar 8, 2004
P
paintballtommy
244
concord, ca
Mar 8, 2004
  • Mar 8, 2004
Hey guys,
I am in the process of refinishing the engine bay for my new motor. I bought the aircraft stripper and all that stuff im gonna need to do the job primer whatever. my main question is will I have to drain my brakes to pull the master cylinder out to do the engine bay and is there anything else i should do before stripping the engine bay?
thanks,
Tommy
ozstang65
313
Queensland, Australia
Mar 9, 2004
  • Mar 9, 2004
Don't have to drain the lines as the master cylinder should be the highest point in the lines anyway, however it is a wise move to flush the lines and install new fluid every couple of years anyway. This is because brake fluid is very hygroscopic (attracts water really well) and rubber brake lines can't fully prevent the fluid from attracting moisture. If flushed regularly, there's less of a chance for your master and slave cylinders to rust up prematurely.
Also make sure to get all of the stripper washed off. This stuff is usually very caustic and will corrode any metal it is left on. Maybe take precautions to prevent it getting in the framerails or any other place you can't get it out of.
Have fun!
2nd Mustang
2,488
Southern California
Mar 9, 2004
  • Mar 9, 2004
Brake fluid does an excellent job of taking off paint, so be careful.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
A
SN95 Hydroboost in a Fox | Brake lines
  • arc_jpiv
  • Sep 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 14, 2026
2000xp8
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
