  • SN95 4.6L Mustang Tech
Driver side Window will not close!!!!!!
  • Thread starter Thread starter shallowreef
  • Start date Start date Jun 26, 2006
shallowreef
illinois
Jun 26, 2006
  • Jun 26, 2006
My driver side window will not close. I know that there is power going to it because when i press the up and down buttons the interior light dims. I had this problem once before but the car was under warranty and they fixed it for me no problem. Now i'm SOL! Is the motor shot? Where are the fuses located on the 02 GTs? Right now i am scheduled to take it in to my mechanic so that he can take a look at it. I feel a five hundred dollar bill coming. Which really sucks. Any advise?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Jun 26, 2006
  • Jun 26, 2006
it might have slipped of its track or the window regulator took a poop
BigChiefSmokem
1,400
Jacksonville, FL
Jun 26, 2006
  • Jun 26, 2006
Try holding down the up button and slamming the door while inside the car.
I recently had the same problem and posted about it. Someone suggested this and it worked.
Mach1Run
333
Wylie, Texas
Jun 26, 2006
  • Jun 26, 2006
I used to have better luck hitting the inside panel just over the motor while holding the up button.
02dragGT
23
Clarence Center, New York
Jun 26, 2006
  • Jun 26, 2006
Mine does this sometimes, usally when its hot out. I just wait till the evening and it goes right up. I'll have to try the hitting method sometime
Dan_Soprano
7,410
54
129
Jacksonville, FL
Jun 26, 2006
  • Jun 26, 2006
that would be me that sugested that. Works like a charm huh!! (a ford tech taught me that)!
BigChiefSmokem
1,400
Jacksonville, FL
Jun 26, 2006
  • Jun 26, 2006
Good to know that when i go in for work at ford due to a problem the tech charges 100 dollars an hour to slam my door while holding the up button down on my window and then call it fixed.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Jun 26, 2006
  • Jun 26, 2006
hey, just remember, even if they do .1 hours work, they ALWAYS round up!!
tomustang
Psychotic Member
3,434
McLean Hospital
Jun 26, 2006
  • Jun 26, 2006
IF it is the same one they worked on AND it's been less than a year, the dealer HAS to work on it for free
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 26, 2006
#10
  • Jun 26, 2006
  • #10
or how about the IAC diag.
step one.. wack with hammer.
step two... start car
But seriously many times it's difficult. How about when it's not the motor and it's a wire with shaffed housing inside the tube between the door and body.
Mike97gt
it doe snot
10,633
Jun 26, 2006
#11
  • Jun 26, 2006
  • #11
NOPE. The dealer is NOT required to repair a warrenty repair after the warrenty period is over.
The reasoning behind this is.
You ( the customer) did not pay for the repair becuase it was under warrenty, ford paid for it. now that the warrenty is over ford is not going to pay again to fix it. the way they looked at it is they paid for it and it laster beyond the period of time they are responsible for the car. so now why should they pay a second time after the peroid they are responsible for.
makes a lot of sense if you think about it.
NYStang2002
231
Wappingers Falls, New York
Jun 26, 2006
#12
  • Jun 26, 2006
  • #12
This happened to me a few times when I leave my window down for a long time usually overnight or when its really hot outside. I first took the door panel off and hit the motor area with a rubber mallet while holding the up button and voila! window up. The last time this happened I just wacked the inside panel around the motor area and fixed it again.
BigChiefSmokem
1,400
Jacksonville, FL
Jun 27, 2006
#13
  • Jun 27, 2006
  • #13
So, shallowreef, did it work or not?
V_Eight
617
ATL
Jun 27, 2006
#14
  • Jun 27, 2006
  • #14
I had been having a problem for over two weeks now. I just walked out and tried this. The second time it fixed it. I about **** myself.
Thank you so much guys!
shallowreef
illinois
Jun 27, 2006
#15
  • Jun 27, 2006
  • #15
Well i took it to my mechanic and he took the door apart to see what was going on. Then he walked back into his garage came out witha rubber mallet and hit the door right around where the motor was while holding the up button. Sure enough it went right up. I have the window closed right now because i don't want to take a chance of it getting stuck down again. I am going to order a new motor and have it replaced. I don't want to deal with this s**t again. Its gonna run me about 300 to get the new one installed. I think i'm done modding my car. I can't afford to pay for mods and take care of minor stuff like this too.
Thanks to all of you guys for helping me out. Luckily my mechanic didn't charge me for it. I know i can always count on stangnet to help me figure out my car problems.
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 27, 2006
#16
  • Jun 27, 2006
  • #16
http://eleanor.pro3i.com/showpost.php?p=6211598&postcount=2
U.M.
Dan_Soprano
7,410
54
129
Jacksonville, FL
Jun 27, 2006
#17
  • Jun 27, 2006
  • #17
U.M.
damn you!! I know I have suggested this before also.....
U
Uncle Meat
Banned
Jun 13, 2002
Prattville, Alabama
Jun 27, 2006
#18
  • Jun 27, 2006
  • #18
Just pickin' on ya Dan...
U.M.
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
2017 Driver side window will not work
  • Jamesg33
  • Jan 31, 2023
  • 2015 - 2023 (S550) Mustang -General/Talk
2K
2015 - 2023 (S550) Mustang -General/Talk Jan 31, 2023
General karthief
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
J
  • JRC99
  • Apr 19, 2025
JRC99
J
C
Electrical 90LX Power Window Problems, Passenger Side wont roll down
  • cturboaddict
  • May 15, 2022
Fox 5.0 Mustang Tech May 15, 2022
cturboaddict
C
