  • 1994 - 1995 Specific Tech
Drivers side head removal HELP!!!!
  • Thread starter Thread starter stud4u13
  • Start date Start date Jun 26, 2005
stud4u13
10
  • Jun 26, 2005
:damnit: I've been trying for the last two days to get the drivers side off of the engine. I can seem to get the damn powersteering and Ac compressor off of the bracket so that I can pull it out. Is there some kind of trick to this that I am missing . I've already rounded off one of the mounting bracket bolts trying to get the damn thing out . Its really starting to piss me off . If you guys got any suggestions I'm listening
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Jun 26, 2005
  • Jun 26, 2005
Pull the PS. pulley off then you'll be able to get to all of your bolts to get that bracket off... Dont think you need to remove the actual PS pump and AC compressor off of the bracket.
Use a PS. pulley puller to get the pulley off... Local parts store should have one.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Jun 26, 2005
  • Jun 26, 2005
Ditto although I can get mine off now with out it, I forgot what I did but I can slowly back out that middle bolt and then the whole bracket comes off. I think I mixed some bolts around or something tho.
1105
May 3, 2003
3,841
Daytona Bch, FL
Jun 26, 2005
  • Jun 26, 2005
I ment to drill out one of thoes holes on the outter side of the PS pulley so I can get to the bolts that hold the actual pump in place so I could just take that off instead of pulling that damn pulley because its a bitch to get off.
stud4u13
10
  • Jun 26, 2005
I pulled the ps pulley off but the problem is that the last bolt for the bracket has been rounded off. so every damn socket I put on it wont stay it just spins off if I give it any kind of torque. Its the bolt that is right behind the pulley that you cant get to unless you pull the pully off. Any suggestions
mootang
907
texas
Jun 26, 2005
  • Jun 26, 2005
cut the head off. pull the bracket off and then go get a new bolt.
4Jenna
4,326
AZ
Jun 26, 2005
  • Jun 26, 2005
GRGT1994
1,034
  • Jun 26, 2005
I rounded a bolt over when doing my gears. So I picked up a kit at Sears (turns out that any big box hardware store or auto parts store will have it too). It's a socket kit made of hardened metal that cuts into the rounded over bolt head.
That might be easier than cutting it out. Anyway, I would start with that, and cut it out if you have to.
haulbalz
448
  • Jun 29, 2005
NO, It's a bitch getting back on...
1105
May 3, 2003
3,841
Daytona Bch, FL
Jun 29, 2005
#10
  • Jun 29, 2005
  • #10
negative
getting it back on is a lot easier... last time i had my pulley off it was in 5 pieces because we had to cut it off... never had to cut it to put it back on.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Jun 29, 2005
#11
  • Jun 29, 2005
  • #11
Get that kit that's supposed to turn rounded bolt heads when they are stripped. Sears sells them.
If that doesn't work, you can try a really big set of vice grips, lock onto it HARD, and try that. But my guess is it will be easier to cut the head off, remove bracket, then use vice grips on the shaft section of the bolt to back it out.
Scott
cavscout371
277
#12
  • Jun 30, 2005
  • #12
I've had pretty good luck with easy outs. Another thing you can do is use a flat sharp edge punch (dont know the techinical name for it) and whack it with a hammer and try and get it to turn I've used that method more times than I ve cared too. I just don't know how well you'll be able to get in there if its still in the car
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 30, 2005
#13
  • Jun 30, 2005
  • #13
I thought about that a while back but was afraid the pulley would become out of balance and do damage to the pump.
What are your thoughts about it?
btw, I found the correct puller for less than $20 and it works like a champ for putting it on and taking it off.
Later
Grady
CManT1914
3,172
Killeen, Texas
Jun 30, 2005
#14
  • Jun 30, 2005
  • #14
Later
Grady
Will my balancer puller work for the p/s pulley too?
scarless
175
#15
  • Jun 30, 2005
  • #15
Not likely. Balancer pullers are really only meant for that one purpose.
F
fiveohh94gt
277
#16
  • Jun 30, 2005
  • #16
NO, they're compleatly different
CManT1914
3,172
Killeen, Texas
Jun 30, 2005
#17
  • Jun 30, 2005
  • #17
Looks like I'll be going back to the parts store before I start my project.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 30, 2005
#18
  • Jun 30, 2005
  • #18
10bux
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=40749
Most likely not the greatest quality, but then again, its not like your gonna use it every day, lol.
Later
Grady
scarless
175
#19
  • Jun 30, 2005
  • #19
I have that set, it's nice and $10 is a deal. Not for pulling a dampner though, but you can rent those from auto-parts stores.
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
2K
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
