I will respectfully disagree. The DS bolts come from the factory with threadlock on them (that is why some folks struggle so much getting them out). And if threadlock is not used upon reinstallation, the bolts can back-out. That is not a game I would want to play.Methodical said:.... and always and I mean always use "antiseize" on any bolt under the car, especially exhaust bolts, once removed, including the driveshaft bolts. You will have a much easier time removing them in the future. Peace
HISSIN50 said:I will respectfully disagree. The DS bolts come from the factory with threadlock on them (that is why some folks struggle so much getting them out). And if threadlock is not used upon reinstallation, the bolts can back-out. That is not a game I would want to play.
I've run my DS like this since changing to an aluminum DS (10/1998) and never had an issue of bolts backing out. And I've removed the DS many times since then to install cats for emissions, change clutch, rebuilt engine (remove tranny) and bolts were never loose. They were all tight. But that's my opinion and that is what has worked for me. Just One Man's Opinion. Peace
Methodical said:Here's how I got the bolts off the the first time. I used a 12mm 12pt wrench and a sludge hammer. I tapped the wrench with the sludge hammer to loosen the bolts. Option, you can get a long pipe that fits over the wrench for leverage - same theory as a breaker bar. Also, remember to mark the draftshaft and always and I mean always use "antiseize" on any bolt under the car, especially exhaust bolts, once removed, including the driveshaft bolts. You will have a much easier time removing them in the future. Peace
sludge hammer isn't very good for this application. You might want to try another the sledge kind.....lol.....sorry..DS to trans dosent really need to be indexed, it should just slide right in the back of the transdroptopford 5 0 said:just a somewhat-related question to the subject... if you should index all d/s pieces when installing/ un-installing them, how are you to install a new driveshaft, new rear-end, or new transmission when theres obviously no previous way of indexing them so they lign up?.. im planning on putting in a new t-5 and wonder how i can allign it with the old driveshaft?
