Drop Springs + UCA Drop = still too high. any recommendations before I cut my coils?
  • Thread starter Thread starter Snail50
  • Start date Start date Jun 16, 2004
First Prev 2 of 2
Snail50
787
Miami
Jun 16, 2004
#21
  • Jun 16, 2004
  • #21
302 coupe said:
not really, diameters are within a fraction of each other. 225/60/15's are 25.6 tall, 235/45/17's are 25.3 tall. Sounds like a sweet setup you've got, maybe the springs were mis-labeled or something
Post some pics when you get 'er done
I'm not too sure of the tire math... but I know that my old tire setup on my 14" rims is taller than the one on my 17" rims.
I'm really happy with the setup so far, thanks. I'm going to try to do my coils & LCAs tonight if I can, and once it's all level, I'll post up pics.
302 coupe
1,952
Macon, Ga.
Jun 16, 2004
#22
  • Jun 16, 2004
  • #22
looks good opentracker, that's how mine sits only mine is about a 1/2" or so higher all around. That Boss-like stripe is kickin' too!
Tire math
225/60/15.....225 divided by 25.4=8.86, 8.86x.60=5.32, 15+5.32+5.32=25.64
235/45/17.....235 divided by 25.4=9.25, 9.25x.45=4.16, 17+4.16+4.16=25.32
Snail50
787
Miami
Jun 16, 2004
#23
  • Jun 16, 2004
  • #23
Opentracker: that's a great stance. I replaced the spring perches with new ones with poly bushings. they move very freely.
Jason: you mounted the prop. valve in the rear of the car? I thought it went up front near the MC?
Snail50
787
Miami
Jun 16, 2004
#24
  • Jun 16, 2004
  • #24
Tire math
Argh. I'm getting a headache just looking at that. everything happens for a reason, and there was a reason I majored in English....
j/k. thanks for the formula.
Snail50
787
Miami
Jun 16, 2004
#25
  • Jun 16, 2004
  • #25
and BTW, 302Coupe, it sounds like our setups will look about the same. Which 4 wheel discs do you have?
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jun 16, 2004
#26
  • Jun 16, 2004
  • #26
Bobv is right about getting the lower control arm leveled out; it is in the directions. I called them to ask about this and they said it would provide the best geomeetry for improved handling. If you check yours and it's already level, I would look into other options. If it's not, cut away, but I think you will want to switch to lighter springs if you do; cutting them increases spring rate. I would go with the variable rate springs in their lighter rates and then cut them to get it right.
302 coupe
1,952
Macon, Ga.
Jun 16, 2004
#27
  • Jun 16, 2004
  • #27
I have the infamous granada/versailles combo, low-tech and works like a champ.
BAD67FUN
589
Wisconsin
Jun 16, 2004
#28
  • Jun 16, 2004
  • #28
It does it's job wherever it's put in the rear line. I just did not like my mounting options available in the engine compartment. So instead of hacking it in there... I opted for the easy location.
Snail50
787
Miami
Jun 16, 2004
#29
  • Jun 16, 2004
  • #29
hey, if it works, it's all good.
Snail50
787
Miami
Jun 16, 2004
#30
  • Jun 16, 2004
  • #30
gotcha. thanks.
Snail50
787
Miami
Jun 16, 2004
#31
  • Jun 16, 2004
  • #31
Okay, I cut 1/2 coil off, which dropped the front about an inch. I might have to cut a little bit more, because my LCA's are slightly closer to the ground on the outboard ends. We'll see if it settle more.
Thanks all for your input!!!
BAD67FUN
589
Wisconsin
Jun 17, 2004
#32
  • Jun 17, 2004
  • #32
I'd recommend driving the car for about a week or so and truly let it settle in before cutting more. Be patient and you'll be better off...
Snail50
787
Miami
Jun 17, 2004
#33
  • Jun 17, 2004
  • #33
Yeah, patience is the key. I just want to do everything at once....
But I do need to get the suspension done and aligned so that I can take it out and break in the brakes ( ) properly.
First Prev 2 of 2
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
19K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
R
Alignment specs for daily driver - Shelby drop, 1" springs all around
  • rgsauger
  • Sep 5, 2019
6K
1965 - 1973 Classic Mustangs -General/Talk- Sep 7, 2019
zookeeper
Coil spring
  • 2002montrealGT
  • Jun 14, 2018
1996 - 2004 SN95 Mustang -General/Talk- Jun 16, 2018
2002montrealGT
C
  • Locked
Expired Rotisserie Restored 1964 1/2 Ford Mustang Coupe Kingsburg, Ca
  • California Stang
  • Dec 19, 2015
  • Classic Mustangs For Sale
5K
Classic Mustangs For Sale Jan 14, 2016
California Stang
C
