Dropping the Engine in
  • Thread starter Thread starter Burgundystang
  • Start date Start date May 19, 2004
Burgundystang
53
TN
May 19, 2004
  • May 19, 2004
Hey guys,
Ive spent the last two hrs. today, and two hrs. on sunday trying to put my rebuilt engine back where it belongs. We finally got it installed on sunday only to find out that the flexplate and torque converter bolts werent lined up. I was just wondering if yall had any suggestions or tips on installing the engine; they would be greatly appreciated. Thanks.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
May 19, 2004
  • May 19, 2004
I use 2 treaded studs in the bell housing bolt holes to guide in alining.
{make sure that you use holes that are easily removable}
with auto's I put the converter bolts at the hours 3,6,9,12 and turn the crank to match.
With sticks i make sure the spline grooves are at 12.
PB
67coupe351w
424
Portland, OR
May 19, 2004
  • May 19, 2004
cant you just rotate either the engine or the torque converter until the holes line up? or are they not lining up in a diffrent way?
Burgundystang
53
TN
May 20, 2004
  • May 20, 2004
The reason i couldnt do that on sunday was that the studs from the torque converter were pressed up against the flexplate so hard that when i turned the flexplate the torque converter turned with it. What do yall hook up first, the converter to flexplate, bell housing (all at the same time?), or engine mounts?
Edbert
3,548
32
109
Austin TX
May 20, 2004
  • May 20, 2004
I would do the bellhousing before the TC-to-flexplate nuts, just make sure the TC bolts are in their holes before fastening the bellhousing. There's no real rule to getting the mounts on before or after the tranny but here's what I do.
Connect the upper part of the engine mount to the block but keep them VERY loose for maneuverability.
Connect the lower part of the engine mount to the frame but keep them VERY loose for maneuverability.
Lower the engine into approximate place and push the long bolts through the mounts (connect the upper and lower portions) but do not tighten ANY part of the mounts until the tranny is connected. Make sure the middle and rear tranny mounts are in the correct locations.
Then tighten the upper and lower engine mounts, then toghten the middle (long) bolts on the engine mounts.
___________
Like I said this is not some sort of rule but it has worked fine for me many times.
M
my66coupe
1,134
Arizona fountain hills
May 20, 2004
  • May 20, 2004
If you dropped the engine and tranny in as one hole assembly you should have done this before dropping it in. I simply make the studs at 12, 3, 6, and 9 o'clock positions and same with the flexplate. If you line it up and the studs still dont appear, just install the tranny loosley to the engine, and rotate the motor a back and forth until the studs slip through their holes.
Mike
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
May 20, 2004
  • May 20, 2004
One note: the t.c. has to be fully seated in the tranny. Turn the t.c. while putting inward pressure on it; you should hear at least four or five clicks.
Burgundystang
53
TN
May 20, 2004
  • May 20, 2004
I never pulled the tranny, and i heard quite a few clicks when installing the TC.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
N
Drivetrain AOD install - issue lining up TC studs to Flexplate holes
  • notch351w
  • Sep 28, 2024
Fox 5.0 Mustang Tech Oct 4, 2024
notch351w
N
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
G
Front Sway bar HELP
  • Grabberblueguy77
  • May 28, 2025
2005 - 2014 S-197 Mustang -General/Talk- May 28, 2025
gkomo
